They feature MegaZoom III for real-time, high-resolution XGA waveform viewing with 256 levels of colorintensity grades, and memory depth to a full 8 Meg points. The scopes can accept 16 logic-timing channels. The devices come standard with LAN, GP-IB, and USB interfaces as well as an additional front-panel USB port to replace limited-capacity floppy drives. The front-panel USB port lets designers store large memory records, screen images, and settings on standard higher-speed, higher-capacity USB memory sticks.
Agilent
395 Page Mill Rd.
Palo Alto, CA 94306
(877) 424-4536
www.home.agilent.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
