Springloaded, Steel-Side Thrust Pins
Spring-loaded, steel-side thrust pins hold, position, and clamp workpieces.
A threaded body adjusts protruding height. The metric-sized zincplated pins come with seals (yellow finish) or without (blue passivated finish).
J.W. Winco Inc., Box 510035, New Berlin, WI 53151, (800) 877-8351,jwwinco.com
