Clean-Design Cylinders
May 10, 2007
The CDN Series clean-design cylinders are streamlined, easy-to-clean, and corrosion resistant.
The units have a smooth profile
with no edges or angles, nonpooling surface, surface-coated aluminum housing, and are resistant to cleaning agents and caustic wash downs. Piston diameters range from 32 to 100 mm and stroke lengths are 10 to 2,000 mm.
Festo Corp.,
395 Moreland Rd., Box 18023, Hauppauge, NY 11788,
(631) 435-0800,
www.festo.com
June 27, 2025
June 25, 2025
June 25, 2025
