New Compressed Air Hose (CAH) is designed to withstand the demanding requirements of air compressors. It includes a nitrile synthetic-rubber inner tube, wire and fiber reinforcement, and outer fiber-braid cover. The hose handles pressures to 500 psi and compressed air temperatures to 158°F. It is also suitable for petroleum-base hydraulic fluids, lubricating oils, antifreeze, polyol esters, water, and water/glycol mixtures. The CAH line is compatible with 26 Series Parkrimp fittings and is available in sizes from –4 to –40. Request a copy of Product Bulletin 4480-B133-US.
