Pneumatic Products: Energy-Efficient Vacuum Pump
P5010 vacuum pump reportedly gives the highest possible vacuum performance relative to energy consumption and features Coax cartridge technology.
Nov. 22, 2008
The P5010 vacuum pump features Coax cartridge technology and reportedly gives the highest possible vacuum performance relative to energy consumption. The light and compact design helps reduce the weight of end-of arm-tooling and move the pump closer to suction cups for faster response. To further reduce energy consumption, an optional air-saving function minimizes compressed air use when handling nonporous products. And a control unit with valves for on/off and blow-off activation caters to the needs of packaging and printing companies that handle porous products.
Piab
65 Sharp St.
Hingham, MA 02043
(781) 337-7947
piab.com
