New products: Field serviceable check valves
Power Generation Chek Valves can be disassembled and serviced in the field using rebuild kits. Designed to customer requirements, the valves are available with or without a removable, washable Hi- Bar safety screen. The unit’s operate to 450°F and feature low leakage and high flow. The valves are suitable for use in purge air, water injection, and liquid-fuel applications.
The Lee Co., 2 Pettipaug Rd., Box 424, Westbrook, CT 06498, (860) 399-6281, theleeco.com
