Pureloc compression fittings, for mating fluoropolymer tubing, come in a dozen styles. The fittings, made from virgin-grade, chemically inert PFA fluoropolymer, target pure-fluid applications that demand contamination- free systems. The devices offer unrestricted flow, as well as lock and sealability.
The precision-made fittings consist of four parts — nut, gripper, ferrule, and body — for leakproof connections. The nut’s ridged surface makes it easy to grip and tighten. The seethrough body lets users see they are properly installed. Purelocs can be disassembled and reused. Available styles include elbows, straight connectors, tees, adapters, and reducing and bulkhead types. Sizes range from 1/8 to ¾ in.
NewAge Industries Inc. 145 James Way Southampton, PA 18966 (800) 506-3924 newageindustries.com
