Product Spotlight: Membrane-Switch Spacer
XyWeld spacer features a specialty adhesive bonded with a heat-activated process to produce a spacer
The XyWeld spacer features a specialty adhesive bonded with a heat-activated process to produce a spacer that is more robust than a standard PSA. XyWeld lets designers use a membrane switch in environments exposed to water, dust, high or low temperatures, and harsh cleaners. The new spacer has a 1 million actuation life cycle and is designed for use in temperatures from -40 to 70°C.
Xymox Technologies
9099 West Dean Rd.
Milwaukee, WI 53224
(414) 362-9000
xymox.com
