New Products: Rear-Mount LEDs
May 19, 2009
The CRM Series of rear-mount LEDs lets users remove the LED from a panel without removing terminations.
The CRM Series of rear-mount LEDs lets users remove the LED from a panel without removing terminations. The LED’s nickel-plated brass housing has a flat side to prevent rotation when mounting. The indicators secure to front panels with a nickel-platedbrass hex nut. The LEDs, fitted with dual nitrile O-rings, are internally potted to IP66, making them suitable for high-vibration applications. The indicators feature 20 ±2 lb-in. mounting torque; 10- lb pushout force; and daylight-readable single-color LEDs that are also available as bicolor, tricolor, fullcolor RGB, and blinking. Internal resistors for 5 to 60 Vdc or 120 Vac with LED pin terminations or insulated wire leads are available.
Wilbrecht Ledco Inc.
1400 Energy Park Dr., Suite 18
St. Paul, MN 55108
(888) 323-8751
www.wilbrechtledco.com
In the rapidly evolving landscape of industrial manufacturing, reliability, productivity, and worker safety take precedence. However, traditional connectivity approaches often...
June 6, 2025
Amidst the rapid evolution of electronics manufacturing, reliability, productivity, and worker safety remain paramount concerns. Yet, traditional connectivity methods often falter...
June 6, 2025
While many within the industrial manufacturing sector grasp the importance of smart manufacturing for optimizing processes, boosting productivity, and future-proofing operations...
June 6, 2025
For electronics manufacturers grappling with formidable challenges, navigating the path to success requires adapting to the dynamic landscape of the industry. How can electronics...
