New Products: Multiport Junction Blocks for Sensors
Zip-Port multiport junction blocks allowing multiple sensors to be wired to a single block with one cable connecting to the control panel
Zip-Port multiport junction blocks allowing multiple sensors to be wired to a single block with one cable connecting to the control panel. Available in field-wireable or 5-m cable versions, the blocks feature four and five-pin M12 connectors in four, six and eight-port models, and a choice of one or two I/O per port. The blocks provide 24-Vdc and 120-Vdc/Vac operation in –20 to 80°C temperatures, as well as IP67 protection when all ports are either connected or covered with recommended protective caps.
The five-meter integrated cable series come with three 18-gage wires for power connection and four to sixteen 22-gage wires for I/O connections, depending on the number of ports.
AutomationDirect
3505 Hutchinson Rd.
Cumming, GA 30040
(800) 633-0405
www.automationdirect.com
