New Products: Proportional Flow-Control Valve
Normally closed two-way valve provides proportional flow control from direct, PFM, PNM, or PWM signals.
Normally closed two-way valve provides proportional flow control from direct, PFM, PNM, or PWM signals. It has nine outlets, which can be controlled individually in multiples of three, or all nine. Each outlet provides up to 180 Nl/min flow at six bar, with operating pressure from two to eight bar. It accommodates nonlubricated dry air filtered to 40 μm. The IP62-rated valve opens or closes in <5 msec with a maximum frequency of 500 Hz.
Matrix S.p.A.
17476 W. Winter Pine Way
Fair Oaks Ranch, CA 91387
(661) 299-2762
www.matrix.to.it
