New Products: Cabinet-Cooling System
The digital Electronic Temperature Control (ETC) Cabinet Cooler System keeps electrical enclosures cool while minimizing compressed-air use. The system accurately maintains a constant temperature that is slightly under the maximum rating of the electronics.
The digital Electronic Temperature Control (ETC) Cabinet Cooler System keeps electrical enclosures cool while minimizing compressed-air use. The system accurately maintains a constant temperature that is slightly under the maximum rating of the electronics. The ETC’s solid-state circuitry detects the slightest change in temperature. When the setting is exceeded, the cooler circulates 20°F air through the electrical enclosure to prevent a high-temperature malfunction.
Housed in a strong polycarbonate plastic, the ETC has a sealed membrane pushbutton control that is suitable for use in NEMA-4, 4X, and 12 environments. Cooling capacities up to 2,800 Btu/hr are available.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249
(800) 903-9247
www.exair.com/etc.htm
