Modular solenoid-valve connectors - Canfield Connector
The Series 5000 solenoid-valve connectors are protective enclosures for electrical connection in conjunction with hydraulic and pneumatic solenoid valves.
The Series 5000 solenoid-valve connectors are protective enclosures for electrical connection in conjunction with hydraulic and pneumatic solenoid valves. Available in mini, ISO, and submicro styles, the connectors’ modular design lets them be used where rapid installation and service are required. The ISO and 8-mm submicro connectors connect valves using the DIN 43650/ISO 4400, EN175301-803:2000 specification, and the mini and 9.4-mm submicro connectors are industry standards, which permit industry interchangeability.Canfield Connector, 8510 Foxwood Court, Youngstown, OH 44514, (330) 758-8299, www.canfieldconnector.com
