UV-light-curable silicone
Nov. 18, 2009
Cure-Point 9440-A/B UV/visible light-curable silicone potting and sealing material is intended for applications where fast cure, enhanced thermal performance, and room-temperature shadowed-area cure are required.
Cure-Point 9440-A/B UV/visible light-curable silicone potting and sealing material is intended for applications where fast cure, enhanced thermal performance, and room-temperature shadowed-area cure are required. The material withstands long exposure to temperatures ranging from below -40° C to above 200° C. This makes it superior to RTV silicones and heat-cure silicones which require longer cure times or elevated temperatures to cure. Dymax Corp., 318 Industrial Lane, Torrington, CT 06790, (860) 482-1010, www.dymax.com
June 27, 2025
June 25, 2025
June 25, 2025
