Keypads - EAO Switch Corp.
Feb. 11, 2010
The M Series of keypads, with easy panel configuration and adaptable layouts, accommodate a wide range of designs.
The M Series of keypads, with easy panel configuration and adaptable layouts, accommodate a wide range of designs. The keypad’s modular design lets designers specify any number of keys, as well as the standard 4, 12, and 16-key layout.
Features of the vandal resistant keypads include anti-twist, anti-pull off, and non sticking keys; blue, red, yellow, green, or white LED illumination; multiple button shapes and colors within one keypad; blank spaces for separation between keys in one unit; variable key travel; plastic or aluminum keys; and click-dome or membrane technology.
EAO Switch Corp., 98 Washington St., Milford, CT 06460, (203) 877-4577, www.eao.com
Aug. 22, 2025
Aug. 22, 2025
Aug. 21, 2025
