Frameless motor hits 70,000 rpm - BEI Kimco Magnetics
The Model DIP14-14-00A is a frameless permanent-magnet BLDC motor that measures 1.4 in. in diameter × 1.4-in. in axial length.
Oct. 21, 2010
The Model DIP14-14-00A is a frameless permanent-magnet BLDC motor that measures 1.4 in. in diameter × 1.4-in. in axial length. Its rotor/stator part-set configuration lets the rotor directly couple to the load for operating efficiency, minimal parts count, and a compact form factor. A stainless-steel sleeve secures the magnets in place at the extreme speeds. The motor is capable of speeds to 70,000 rpm.
BEI Kimco Magnetics, 2470 Coral St., Building D, Vista, CA 92081, (800) 572-7560, www.beikimco.com
© 2010 Penton Media, Inc.
