Design by objective: EASE OF USE
On-board amplifiers
The MC73110 brushless motor control IC developer's kit (DK73110) with mosfet amplifiers offers an easy way to build high-end motor controllers.
FEATURES & BENEFITS
- Incorporates velocity and current loop, commutation, high-performance half-bridge mosfet switches, and integrated motor connections
- Proportional integral current control algorithm drives power stage
- Drives 3-phase brushless motor to 10 A; inputs analog or digital command signals; requires single voltage high-power unit
- Operates in internal profile, velocity, or torque modes
PERFORMANCE MOTION DEVICES INC.
Lincoln, Mass.
(781) 674-9860
www.pmdcorp.com
Circle 238
Programmable machine controller
PMC-328 comes with graphical programming software for ease of use and powers, drives, and controls any 2 or 4-phase stepper with currents to 3 A.
FEATURES & BENEFITS
- Control via host computer with standard serial cable or by loading up to 100 lines of programming into internal, non-volatile memory
- Housing is a 50.8 × 96.5 × 223.5-mm mountable enclosure
- Resolution programmable to 8 mini-steps per full step
- Flexibility offered with eight general purpose I/O lines, one general purpose up/down counter, two limit and jog inputs, and home and run program inputs
ADVANCED CONTROL SYSTEMS CORP.
Pembroke, Mass.
(781) 829-9228
www.acsmotion.com
Circle 239
Intelligent sensors
The iSensor family of intelligent sensors integrates a dual-axis MEMS accelerometer, digital temperature sensor, power-management circuitry, and embedded firmware.
FEATURES & BENEFITS
- Provides fully calibrated digital outputs for motion and inclination measurements
- Embeds detection, calibration, compensation, and filtering functions in 9 × 9-mm package
- Application-specific programmable power options available; output data provided via serial port interface
ANALOG DEVICES INC.
Wilmington, Mass.
(800) 262-5643
www.analog.com
Circle 240
Fiber-optic sensors
D10 compact, DIN-rail-mountable fiber-optic sensors are available in three models with choice of bipolar discrete, dual-discrete, and analog-discrete outputs.
FEATURES & BENEFITS
- D10 Expert with numeric display offers 4-mode power and speed settings and discrete outputs of 50 and 200 msec and 1 and 2.5-msec response; analog output has 1-msec response
- D10 Expert with bargraph display offers bipolar discrete output with one current sourcing and sinking, and 500 or 200-µsec response in normal or high-speed mode
- D10 Discrete output model features 12-turn manual adjustment, bipolar discrete output with one current sourcing and sinking, and 200 or 500-msec response
BANNER ENGINEERING
Minneapolis, Minn.
(888) 373-6767
bannerengineering.com
Circle 241
Motion control programming
LinkMotion 32-bit machine driver software simplifies programming motion control boards by queing files to print, speeds design-to-manufacturing process, and eliminates process or controller hardware.
FEATURES & BENEFITS
- Compatible with many motion control boards, steppers, brushed servos, and brushless servo motors
- Configured as closed or open-loop
- Cuts system development and time-to-market cycle; reduces cost of operation for lifetime
- Loads easily using Microsoft Windows and resides in background
SOLUSTAN INC.
Needham, Mass.
(781) 449-7666
www.solustan.com
Circle 242
