Spotlight bearings and slides
Steel bearings Custom HNRC bearings are made from high nitrogen steel and offer high corrosion resistance and fatigue life. Features & benefits Nitrogen
Steel bearings
Features & benefits
  • Nitrogen and high chromium offer stronger resistance than 440C stainless
  • Hardened and tempered HNCR provides hardness (58HRC) comparable to 52100 steel
  • HNCR steel yields fatigue life better than 51200
  • Available in custom-engineered sizes
MRC Bearings Services
Kulpsville, Pa.
(716) 661-2727
www.mrcbearingservices.com
Circle 205
Ceramic ball bearings
Full ceramic and ceramic hybrid ball bearings absorb heat, are extremely resilient, achieve higher speeds, and reduce overall weight in harsh environments.
Features & benefits
  • Ceramic silicon nitride balls are 10 times stronger than steel balls and hold surface finish longer
  • Smooth surface reduces friction between balls and races
  • 35% less thermal expansion and 50% less thermal conductivity than steel balls
  • Eliminate scarring and run cooler due to less micro-weld adhesion
Boca Bearing Co.
Delray Beach, Fla.
(800) 332-3256
www.bocabearings.com
Circle 206
Spherical plain bearings
PEL BH spherical plain bearings have grease reservoirs between inner and outer ring of bushing and inner ring and pin for lubrication and long life.
Features & benefits
  • I.D. ranges from 12 to 70 mm
  • Load ratings from 38 to 960 C0 and 220 to 5,300 C
  • Duplex surface treatment provides high surface hardness, conformability, and wear and seizure resistance
HEF USA
Columbus, Ohio
(614) 488-2556
www.hefusa.net
Circle 207
Radial, axial bearings
Max Rail combined bearings can move more than 41,000 lb smoothly using a linear bearing system with integrated two-axis bearings, bearing flange plates, rails, and rail clamps.
Features & benefits
  • Available in 11 sizes for maximum dynamic loads of 5,395 lbf radial and 2,248 lbf axial to 41,140 lbf radial and 18,434 axial
  • Bearing rails come in lengths to 19.7 ft
  • Adjustable rail mounts and bearing flanges simplify integration
LM76
East Longmeadow, Mass.
(413) 525-4166
www.lm76.com
Circle 208
Rotary slides
NB slide rotary series offers absolutely smooth rotary and linear movement.
Features & benefits
  • Available in sizes from 6 to 30 mm
  • Standard bush contains cylindrically arranged ball elements within retainer that moves inside steel outer race
  • Large steel balls support high loads
  • Assembles with or without outer housings; can be flange-mounted
NB Corp. of America
Deerfield, Ill.
(800) 521-2045
www.nbcorporation.com
Circle 209
Miniature bearings
Precision miniature bearings are available in corrosion resistant stainless steel and high carbon chromium steel.
Features & benefits
  • Medium and large sizes available, including extra thin and flanged
  • Bore diameters from 0.6 to 9 mm; 2.5 to 30 mm O.D.
  • 68 to 4659 Cr (N) load rating
Sapporo Precision Bearings USA LLC
Sarasota, Fla.
(941) 358-1655
www.spb-usa.com
Circle 210
