Spotlight: Brakes & clutches
Hysteresis brakes
PHT-D hysteresis brakes operate by double permanent magnets and have no wear, making them suitable for constant tension applications as well as torque limiting applications.
Features & benefits
Torque ranges from 0 to 62 lb-in. in 9 models
Deliver torque regardless of slip speed
Smaller models have maximum speeds of 3,600 rpm; larger models have maximum speeds of 1,800 rpm
Can be adjusted individually within given torque range
Ogura Industrial Corp.
Somerset, N.J.
(732) 271-7361
www.ogura-clutch.com
Circle 275
Lift truck brake
LWB hydraulic-actuated, full-circle disc brake uses center hub of wheel rim as a friction surface to eliminate need for bolt-on friction rotors.
Features & benefits
High-strength ductile iron and asbestos-free friction material for reliable stopping and long life
Secondary seals protect piston seals; deflector plate prevents entanglement of foreign objects
Piston seals minimize fluid displacement and come in a variety of materials
Act as a spindle and bearing support for load wheel; minimizes temperatures as wheel's thermal mass absorbs heat
Carlisle Industrial Brake&Friction
Bloomington, Ind.
(812) 334-8727
www.carlislebrake.com
Circle 276
Electromagnetic power-off brakes
Thomson-Deltran AKB spring-set, electromagnetic power-off brakes feature a built-in quiet feature.
Features & benefits
Available in 1.83 to 5 in. diameters
Static engagement with torque from 12.5 to 470lbin.
Fixed field assembly does not rotate; rotor assembly secured to shaft
In power-off mode, fixed and rotating components engage to stop or hold load
Danaher Motion
Wood Dale, Ill.
(866) 993-2624
www.danahermotion.com
Circle 277
Capping clutch
Magnetic capping clutch features smooth torque magnetic technology to eliminate pounding of traditional synchronous headsets.
Features & benefits
Reduces variation of removal torque; improves process capability
Eliminates vibration and over-tightening
Easy-to-use setting scales for top-load spring and static torque
All stainless-steel construction, quad seals, and drain holes for frequent washdown
Warner Electric, Div. of Altra Industrial Motion
South Beloit, Ill.
(888) 350-1891
www.warnerelectric.com
Circle 278
Hollow-shaft clutch
Clutch uses magnetic particles for variable, smooth slip torque, torque limiting, and soft starts.
Features & benefits
Torque ranges from 1 to 38 lb-ft
Horizontally shaft-mounted
Torque transmitted with keyed shaft; input shaft driven by belt and pulley
300 W heat dissipation
May be used as a brake for controlling payout tension
Placid Industries Inc.
Lake Placid, N.Y.
(518) 523-2422
www.placidindustries.com
Circle 279
Lightweight brake
Arc brake is spring-applied and electrically released and functions well on imagers mounted on rotating arms with travels less than 360°.
Features & benefits
Moves ±15° from null position
5 in. long, 1.1 lb-brake supplies 90 lb-ft torque
Five stationary inner disks with friction pucks and six rotating outer disks
Power-off, spring set brake; can be configured as power-on or bi-stable (pulse operated)
Low drag when energized
Sepac Inc.
Elmira, N.Y.
(800) 331-3207
www.sepac.com
Circle 280
Multi-plate clutch
Marine-style clutch features reduced size and weight for higher torque and heat capacities.
Features & benefits
Torques from 75 to more than 1.2 million lb-ft
Speeds over 5,000 rpm
Small OD; large allowable bores
Drop-in replacement for other models, including Eaton CH clutch
Orttech
Solon, Ohio
(440) 498-7458
www.orttech.com
Circle 281
