Spotlight Electric Actuators
Integrated actuator system
Ternary all-in-one linear system controls multiple positions, integrating electronics, precision mechanics, feedback, and software.
Features & benefits
Two sizes — 046 and 032 — for forces up to 600 and 190 N
Linear travel up to 300 mm at 450 mm/sec (046) and 300 mm at 900mm/sec
Use on Profibus, DP, CANopen, or DeviceNet for parallel and serial control, and simultaneous starting
Planetary gearbox ratios from 5 to 25:1; repeatability to ±0.009 mm
alpha gear drives inc.
Bartlett, Ill.
(630) 540-5341
www.alphagear.com
Circle 264
Modular linear system
Smart linear actuator module automation system features DirectConnect technology for easy integration of pneumatic slides, grippers, and rotaries.
Features & benefits
Three models with strokes from 100 to 1,400 mm and stroke speeds from 1 to 1,100 mm/sec
Uses Smart Motor technology for integrated motor and drive
Fully integrated servo/pneumatic motion control
Simple programming and software; online web configurator
De-Sta-Co Robohand
Madison Heights, Mich.
(888) 337-8226
www.destaco.com
Circle 265
Electric actuators
Tritex electric actuators combine brushless servomotors, servo amplifiers, and position controllers in one housing to eliminate external amplifier and cables.
Features & benefits
Linear versions come with front flange, rear clevis, side, or trunnion mounts; rotary come in standard IEC dimensions
3 in. frame size (linear); 90 mm frame size (rotary)
3 to 18 in. strokes, 1250 lbf maximum thrust and 2270 lbf peak; 25 in./sec velocity (linear)
42 lbf-in. continuous, 84 lbf-in. peak torque; 24 and 48 Vdc power; and 1,700 rpm base motor speed (rotary)
Exlar Corp.
Chanhassen, Minn.
(952) 368-3434
www.exlar.com
Circle 266
Linear actuators
Three models of Care 33 linear actuators position equipment safely and reliably while promoting high dynamic load capacity, silent operation, and low current consumption.
Features & benefits
Strokes from 50 to 500 mm
Dynamic load rating from 800 to 2,000 N
Speeds from 8 to 45 mm/sec
Floating gearbox lets load path pass directly through support bearing located in rear attachment
SKF Actuation Systems
Bethlehem, Pa.
(800) 541-3624
www.linearmotion.skf.com
Circle 267
Electromechanical linear actuator
Linear actuator is a leadscrew-driven package that improves accuracy and offers high precision and long life.
Features & benefits
Accepts NEMA size 17, 23, and 34 motors
Kerkote TFE coating, Kerkite high-performance composite polymers, and precision lead screws
Varies speeds within stroke for flexible adjustments of sizes and shapes
Eliminates noise, air, and cost of pneumatics; does not require lubrication
Kerk Motion Products Inc.
Hollis, N.H.
(603) 465-7227
www.kerkmotion.com
Circle 268
Encoder feedback-enabled actuators
Size 11 hybrid linear actuators feature encoder feedback with two channel quadrature TTL squarewave outputs.
Features & benefits
Encoder resolutions from 200 to 1,024 cycles/rev or 800 to 4,096 pulses/rev
Actuator resolution ranges from 0.000125 to 0.002 in./step; delivers thrust to 25 lb
Internal monolithic electronic module converts real-time position, speed, and direction into TTL compatible outputs
LED light and monolithic photodetector array with signal shaping electronics produces bounceless TTL outputs
Haydon Switch & Instrument Inc.
Waterbury, Conn.
(203) 756-7441
www.hsi-inc.com
Circle 269
High-speed actuators
TY series linear actuators are integrated with SHS LM guides and QZ lubricators for long-term and maintenance-free operation.
Features & benefits
Reach speeds to 5 m/sec and accelerations to 5 g
Planetary gearbox ratios of 3:1, 5:1 and 9:1
Utility hardware allows easy construction of multi-axis systems and configuration of drive input shafts
THK America Inc.
Schaumburg, Ill.
(847) 310-1111
www.thk.com
Circle 270
