Pneumatic solutions
Miniature air cylinders
Long-life linear actuators are corrosion-resistant and available as 1-in. bores in brass or stainless steel with a clevis-style tail.
FEATURES & BENEFITS
- Piston rod with two composite bushings in nose and tail assembly supports couples induced by side loads and stress reversals
- 0.78-in. extension and 0.70-in. retraction force factor
- Rebuildable; do not require lubricated air supply
- Minimize stress raisers and failure
BESWICK ENGINERING CO. INC.
Greenland, N.H.
(603) 433-1188
www.beswick.com
Circle 281
Large bore cylinders
HD large bore cylinders offer long life and performance in abusive conditions by combining NFPA dimensional interchangeability and quality components.
FEATURES & BENEFITS
- Available in 5, 8, 10, and 12-in. sizes
- Constructed with heavy-duty external rod bearing in rod end head
- Teflon-impregnated and hard-coat anodized bearing delivers smooth rod motion and maintains rigidity and stability
- Rod gland and bearing can be removed quickly and replaced without disassembling cylinder
MEAD FLUID DYNAMICS INC.
Chicago, Ill.
(773) 685-6800
www.mead-usa.comCircle 280
