Product spotlight: Gears & gearing
Hypoid gearheads
Hypoid gearheads feature a hollow shaft to reach maximum speeds.
Features & benefits
HG2 offers low-backlash in a right-angle design as well as high torque and speed, gear ratios in single stage, low noise, and high efficiency
TK2 flange output design achieves higher torque transmission than traditional designs, high single-stage reduction ratios; and is smooth-running and fatigue resistant
SK2 right-angle design eliminates high-speed co-axial drives and slow-speed right-angle drives; comes with pre-assembled pinion
Alpha Gear Drives Inc.
Bartlett, Ill.
(630) 540-5300
www.alphagear.com
Circle 173
Helical gears
TorqLoc keyless hollow shaft mounting system fits larger parallel shaft helical and helical bevel gear units.
Features & benefits
19 sizes for shaft diameters from 3.25 to 3.75 in. and 80 to 125 mm
Electroless nickel or stainless steel
Interchangeable bushings suit many shaft diameters; eliminate cutting of keyways or turning solid shaft to exacting tolerances
Compact design mounts close to bearings or machine frames
SEW Eurodrive Inc.
Lyman, S.C.
(864) 439-7537
www.seweurodrive.com
Circle 174
Inline gearmotors, speed reducers
Browning series 7000 inline gearmotors and speed reducers feature a modular design for direct interchange with European modular drives.
Features & benefits
Taper connection for easy no-drain drive replacement
20 to 50% higher torque capacity than older units
Quill-style C-face for use with dc and servomotors
Broadest line of motor ends
Emerson Power Transmission
Maysville, Ky.
(800) 626-2120
www.emerson-ept.com
Circle 175
Integrated gear-pulley
Power Pulley timing pulleys feature a compact linear design to provide up to 10:1 reduction.
Features & benefits
Three frame sizes with almost any tooth pitch — English, metric, AT metric, and curvilinear
High bearing capacity supports extreme belt tension
Eliminates external bearings and shafting
Onvio LLC
Salem, N.H.
(866) 685-0404
www.onviollc.com
Circle 176
Gearhead reducers
GHP-20 gearhead reducers suit mixer drive applications and offer low noise, minimal backlash, and quiet and shock absorbent operation.
Features & benefits
3, 4, 5, 9, 12, 17, and 25:1 ratios
Simple 56 C-face motor with less than 5 in. motor extension envelope
Roller gear technology in harmonic and planetary formats
Sealed lubrication system
Gearing Solutions
Solon, Ohio
(440) 498-9538
www.gearingsolutions.com
Circle 177
Metric gearboxes
Siti stainless-steel U-MU metric gearboxes suit aggressive environments by optimizing heat dissipation.
Features & benefits
Power from 0.09 to 11 kW; output torque from 12 to 885Nm
Ratios from 5 to 100:1
Axle base measures 40 to 110 mm
Mount in any 360° position; couple with different size metric motors (B5 or B14 mounting)
Lafert North America
Mississauga, Ontario
(800) 661-6413
www.lafertna.com
Circle 178
