New Products
Shock-resistant encoders
Sendix encoders with 12-bit analog and 14-bit CANopen outputs are designed for applications requiring rugged, high-resolution encoders.
Features & benefits
Die-cast housings, resistance to humidity, IP69K protection
Sensor-Protect technology delivers fully encapsulated electronics and separated mechanical assembly for high resistance to shock (rated to 500 g) and vibration (to 30 g)
Safety-Lockplus technology protects encoder from external debris; LED eases installation and diagnostics; 36-mm diameter; programmable via the bus for node address, baud rate, and termination for fast startup and position or speed data in real time
TURCK
(800) 544-7769
www.turck.com
Circle 160
Compact brushless servomotors
BSM R-series ac servomotors offer a high performance, low-maintenance alternative to stepper motors and dc servos.
Features & benefits
Peak torques to 33.63 lb-in., fast acceleration, small 1.6 and 2.4 in. square bodies
Suitable for packaging and labeling, materials handling, semiconductor manufacturing, winding and printing automation
Cog free, smooth motion at slow speeds, choice of one or two winding stacks; stall torque ratings 1.4 to 11.24 lbin., power and feedback connections via long flying leads
Optional resolver, 2,000-ppr encoder, 24-Vdc brake
Baldor Electric Co.
(479) 646-4711
www.baldor.com/products
Circle 161
Internal locking device
ECOLOC provides strength and stability for heavy-duty applications.
Features & benefits
Applications include conveyor belts, turbine rotors, flywheels, brake drums, gears, sprockets
RfN 7003-7006 devices directly interchangeable with other commercially available locking devices; slit-ring design for greater shaft tolerance variation, backlash-free, eliminates keys; easily installed, adjusted, removed; available from stock with or without flanges; ¾ to 6-15/16 in., 19 to 180 mm
Heavy-duty locking assembly line RfN 7005 Series from 1 to 9 in., to 600 mm
RfN 7009 Series up to 7-15/16 in., 600 mm; other sizes available
Ringfeder Corp.
(888) 746-4333
www.ringfeder.com
Circle 162
Photoelectric sensors
Harsh-duty E58 Series has industry's only background rejection sensor with a two-wire circuit design.
Features & benefits
Resistant to chemical attack, moisture intrusion; can withstand heavy shock and vibration; stainless steel, PVDF, tempered glass components are mechanically assembled using FKM seals to ensure resistance to chemicals
Ac and dc operation in a single unit, 18 and 30 mm diameters, visible red aiming beam for quick setup and alignment
Withstands lubricants, cutting fluids, coolants, and glycols; CE compliant
Omega Engineering Inc.
(888) 556-6342
www.omegamation.com
Circle 163
Wireless encoders
SwiftComm interface allows real-time wireless control for encoders in motion applications to provide robust signals over a secure network.
Features & benefits
Unlike Wi-Fi, exhibits fast boot-up and transmission for seamless interface with existing controls
Cabling eliminated; communicates using point-to-point frequency-hopping 2.4 GHz RF protocol; includes broad security code range, encryption, handshaking, error checking
NEMA 4 enclosures, panel mounting, antennas, wide-range dc power inputs
BEI Industrial Encoders
Custom Sensors & Technologies of Schneider Electric
(800) 350-2727
www.beiied.com/wireless
Circle 164
Digital drive for control
ION 3000 digital drive offers high power of 500 W and 3,000 W to combine many motors for multi-axis motion positioning.
Features & benefits
Magellan Motion Control IC; power amplification; both ION 500 and 3000 available for dc brush, brushless dc, and microstepping motors
CAN bus and serial communications accept commands over a network to control trajectory generation, position and current loops; controls a 3-phase brushless motor using FOC or sinusoidal commutation; profiles include S-curve, trapezoidal, velocity contouring, electronic gearing, pulse and direction
Hardware performance trace, on-the-fly profile changes, PLC-style inputs and outputs
Performance Motion Devices Inc.
(781) 674-9860
www.pmdcorp.com/motion-control-modules-drives
Circle 165
2D laser sensor
New Model ZG profiling laser sensor simplifies setup, shortens inspection time, and reduces hardware with a built-in LCD display.
Features & benefits
Full height and width inspection; captures entire shapes by measuring X and Z axes in msecs; measures four items simultaneously
Real-time profile display on controller's monitor; profile data
Sensing heads capture profiles 3 to 70 mm; remote triggering; calculate measurement values in sync with command input
Sub-micron resolution options; 1.8-in. TFT display as NPN or PNP output models; selectable voltage and current analog outputs
Omron Electronics LLC
(866) 886-6766
www.omron247.com
Circle 166
