New Products: High-strength UV-curing adhesive
Master Bond UV10TK40 modified epoxy adhesive has a tensile strength of 8,300 psi and a Shore D hardness over 75. It cures tack free in air and gels rapidly upon UV light exposure to a Tg over 94°C. The adhesive has low shrinkage and good dimensional stability, heat stability, and chemical resistance.
The adhesive is 100% reactive and contains no volatiles or hazardous solvents. It is recommended for clear coating, sealing, and bonding in any application requiring critical alignment or exact positioning.
Master Bond, 154 Hobart St., Hackensack, NJ 07601-3922, (201) 343-8983, www.masterbond.com
