Machinedesign Com Sites Machinedesign com Files Uploads Pepperl Dg G10 Split
AS-Interface splitters
May 20, 2013
Two new G10 Series AS-Interface Splitters with stainless-steel coupling nuts feature a robust one-piece housing with IP67/IP68/IP69K ratings for use in harsh environments. The VAZ-2T1-FK-G10-V1-V4A and VAZ-T1-G10-1M-PUR-V1-GV4A AS-Interface accessories mount quickly and easily in tight spaces, are immune to vibration, and have gold-plated and machined contacts.
The open, multivendor AS-Interface is designed to reduce the complexity and cost of connecting conventional inputs and outputs, analog transducers, and safety devices to dominant PLCs.
Pepperl+Fuchs, 1600 Enterprise Pkwy., Twinsburg, OH 44087, (330) 486-0001, www.pepperl-fuchs.us
