The Knowledge Cliff: What Happens When Your Most Senior Engineer Retires
They know why the flange on a 10-year-old pump housing is 2 millimeters thicker than the calculation says it needs to be: A supplier had a porosity problem with the casting, the fix was to add material and nobody ever wrote it down. They know which tolerance on the legacy gearbox is real, and which one was copied from an older drawing and never questioned. They know the test the customer will ask for even though the spec doesn’t mention it.
Then they retire, and the department finds out how much of its engineering was living in one head.
What Leaves
The files don’t leave. The CAD models stay, the drawings stay, the change history stays, the test reports stay somewhere on a shared drive. What leaves is the reason behind each of them.
That matters more than it sounds. A model tells you what the part is. It almost never tells you which dimensions were driven by a load case, which ones came from a manufacturing constraint at a supplier you no longer use, and which ones somebody picked because they looked about right. To the next engineer, those three kinds of dimension look identical. So they either leave everything alone, which freezes the design, or they change the wrong thing, and you find out on the test rig or in the field.
Senior engineers carry that map in their heads. They rarely think of it as knowledge at all. To them, it’s just how the product works.
Why the Timing is Bad
Most departments are already paying for this before anyone retires. In the engineering teams my company works with, engineers spend about a quarter of their week looking for information the organization already has, and roughly a third of design work turns out to be redoing something that was done before. Getting a new mechanical engineer to the point where they can work on a mature product line without supervision takes close to two years.
READ MORE: What “Engineering-Grade AI” Actually Requires
When the senior person goes, both of those numbers get worse at the same time. The searching gets longer because the fastest search engine in the building just left. The ramp gets slower because the person who was supposed to mentor the new hire is the one who’s gone. And plenty of companies are trying to hire and bring work back onshore right now, which means more new engineers learning products whose history they can’t see.
What Doesn’t Work
The standard response is the brain dump. Six weeks before the retirement party, someone books a series of meetings and asks the expert to write down everything they know. It produces a long document that almost nobody opens again.
I don't think that’s a discipline problem. Experts asked to write down what they know in general produce generalities. The useful knowledge only comes out when they’re looking at a specific problem: this bracket cracked, why did we go to the thicker section in 2016, what did we try first? Ask them about the bracket and you get 20 minutes of gold. Ask them about “design best practices” and you get a page you could have found in a textbook.
What Does Transfer
Three habits have worked better in the departments I’ve seen. None of them is expensive.
Capture the reason at the moment of the decision. Most change processes already have a field for the reason for change. Make one honest sentence in it mandatory and make reviewers send it back when it says “per discussion” or “updated.” That sentence is worth more 10 years later than the change itself.
READ MORE: Why Text-to-Geometry AI Keeps Failing on Simple Parts
Pair the senior engineer with a junior one on live problems in the last year or two before they leave, and make the junior engineer write down the reasoning—in their own words—after each one. The senior person won’t do it. They don’t need to. The junior person will, because they need it.
Make the record you already have searchable by question, not by part number. A lot of the “why” isn't lost. It’s buried in nonconformance reports, old design review notes, email threads and test summaries, spread across four systems that don’t talk to each other. Nobody can find it because nobody knows which file to open. The engineer’s real question is, “Have we seen this failure before?” and most tools can only answer, “Show me drawing 4471-B.”
Where AI Helps, and Where it Doesn’t
Vendors will tell you AI solves the whole thing. It doesn’t, and the reason is worth being precise about.
AI is very good at the retrieval problem. It can read the nonconformance reports, the test summaries and the old email threads, and answer a question in plain language. It can surface the 2016 test report that explains the thicker section, provided the report exists. For a department where the knowledge was written down somewhere and just never found, that changes the economics of searching completely.
READ MORE: AI is my CAD Co-Pilot
What it can’t do is recover reasoning that was never recorded anywhere. If the only record of why that flange is thick lives in one person’s memory, no model will find it after they leave. And a system that makes up a plausible reason is worse than one that says it doesn’t know, because a confident wrong answer about why a dimension exists is exactly how the next engineer removes material that was there for a reason.
Any tool you put in front of engineers for this job should show the source behind every answer, so the engineer can open the document and check, and it should say so plainly when it has nothing.
So AI raises the value of capturing reasons. It doesn’t remove the need to do it.
What to do This Quarter
Write down the five people whose retirement would hurt you most. For each one, list 10 parts or products where they are the only person who can explain why the design is the way it is. Put a junior engineer on those parts with them, on real work, and have the junior write down the reasoning as it comes up. Then take one of those “why” questions and see whether anything in your current toolset can answer it with a source attached.
If your most senior engineer handed in their notice tomorrow you would lose knowledge either way. That list is how you find out which knowledge, while they’re still around to ask.
Have a question, comment or idea? Get in touch with the Machine Design editors at [email protected].
Maor Farid
Co-founder and CEO, Leo AI
Dr. Maor Farid is the co-founder and CEO of Leo AI. He holds a PhD in mechanical engineering, was a Fulbright postdoctoral fellow at MIT and is a co-inventor on three U.S. patents in geometry-native AI.
Related
AI chatbot assistantVoice Your Opinion!
