Machine Design
  • Resources
  • Members
  • Directory
  • Webinars
  • WISE
  • CAD Models
  • Advertise
    • Search
  • 3D Printing & CAD
  • AUTOMATION & IIOT
  • Robotics
  • Motion Systems
  • Materials
  • Video
  • Data Sheets
  • Topics
    Industry Markets3D Printing & CADAutomation & IIoTFastening & JoiningMaterialsMechanical & Motion Systems Medical DesignRobotics
    Resources
    Machine Design ResourcesWISE (Workers in Science & Engineering)Company DirectorySearch Data SheetsContributeDigital Edition ArchivesCSIA Exchange
    Members
    ContentBenefitsSubscribe
    Advertise
    https://www.youtube.com/channel/UCXKEiQ9dob20rIqTA7ONfJg
    Machinedesign 5924 12365eeallmotion 0
    1. Motors & Drives
    Motor-powered actuator controls flow on conveyors
    June 6, 2013
    Engineers at Mechatronic Techniques, Plano, Tex., recently designed a motor-powered stopper to replace pneumatic and solenoid stoppers on some custom conveyors.
    Elisabeth Eitel
    Machinedesign Com Sites Machinedesign com Files Uploads 2013 06 12365 Ee All Motion 1
    Upon start-up, two signals are internally pulled up to 5 Vdc. Onboard electronics switch between the two when pulses are detected on the Step input.
    Engineers at Mechatronic Techniques, Plano, Tex., recently designed a motor-powered stopper to replace pneumatic and solenoid stoppers on some custom conveyors. The stoppers extend into the conveyor’s material stream to halt the flow of trays containing parts for assembly. When workstations downstream are ready, the stoppers retract and the flow of trays resumes. Previous pneumatic stoppers were inefficient and loud, and solenoid stoppers were often underpowered.
    Machinedesign Com Sites Machinedesign com Files Uploads 2013 06 12365 Ee All Motion 2
    For compatibility with previous machines, Intelli-Inch Controller and Driver power input is 24 Vdc. That way, a PLC can take an input to ground to make the actuator retract, or take the other input to ground to make actuator extend. Mechatronic Techniques is working on an alternative design that will use a single input.
    The engineering team had to get this conveyor subsystem from design to prototype in two weeks and manufacture 35 working units in one month with the help of AllMotion, Union City, Calif.
    The stopper actuators consist of a custom stepper motor with a leadscrew and round-shaft bearing, plus an AllMotion Intelli-Inch stepper controller and driver. It also has a linear shaft with an antirotate feature. The controller/driver generates up to 25,000 pulses/sec and is programmed to run the motor a fixed number of steps clockwise or counterclockwise. At the end of travel, the motor simply stalls.
    The actuator extends (and retracts) 11 mm in 0.5 sec to stop and release 10-tray pileups that push on the cantilevered actuator arm with about 15 lb of sideload. Besides its use in new conveyor machinery, the actuator is a drop-in replacement for pneumatic and solenoid stoppers on older machines.
    Its electrical interface is similar to that for a solenoid: Wire inputs include Step, Direction, Ground, and Power, and two onboard potentiometers set Move and Hold currents.
    Continue Reading
    Brushed vs Brushless Motors: Which is Best for your Application?
    Deliver Robust Automated Systems Through Servo Maintenance
    Smart Factory Solutions that Connect and Protect from Amphenol RF
    Nov. 28, 2023
    Stay Connected and In Control of Your Future Factories with Littelfuse
    Nov. 28, 2023
    Turn to NKK Switches for the Widest Range of Industrial-Savvy Electromechanical Switches
    Nov. 28, 2023
    Unlocking Operational Flexibility in Manufacturing with Industria IoT
    Nov. 28, 2023
    I already have an account
    New
    5 For Friday: Salary Survey Optimism; A New (and Important) Acronym; and Ways to Unleash the Potential of Design
    Formlabs Introduces Fuse Blast for Automated SLS Post-Processing
    Universal Robots Unveils UR30: Relief for Heavy Lifting
    Most Read
    How Much Should a Bolted Joint be Tightened?
    Keeping Enclosures Cool
    Sponsored
    Industrial Automation & Process Controls
    Safeguarding Machines with Hard Guards and Solenoid Locking Switches
    Machine Design
    • About Us
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy & Cookie Policy
    • Terms of Service
    © 2023 Endeavor Business Media, LLC. All rights reserved.
    Endeavor Business Media Logo
