Radial-shaft-seal material for gears
The wear-resistant 75 FKM 260466 is an advanced fluoroelastomer material for radial shaft seals that interacts with aggressive oils in industrial gearbox sealing applications
The wear-resistant 75 FKM 260466 is an advanced fluoroelastomer material for radial shaft seals that interacts with aggressive oils in industrial gearbox sealing applications.
The FKM material has the potential to extend service life (20,000 hr or more) and decrease the downtime of gear applications. A new mixing method lets the material be processed in existing injection-molding process equipment.
Simrit
2250 Point Blvd., Suite 230
Elgin, IL 60123
(866) 274-6748
www.simrit.com
© 2012 Penton Media, Inc.
