O-ring sealing system
The E454 O-ring sealing system is for use in critical commercial-aircraft hydraulic systems.
The E454 O-ring sealing system is for use in critical commercial-aircraft hydraulic systems. The phosphate-ester fluid hydraulic sealing system is designed to perform for years in primary and secondary flight controls and braking systems of commercial aircraft.
Simrit
47690 East Anchor Court
Plymouth, MI 48170
(866) 274-6748
