Antivibration base mounts
The V12Z06MA...Series of conical antivibration base mounts dampen shock and vibration for compression loads up to 1,632 kgf (3,598 lbf). The mount’s metric housing is zinc-plated steel and the isolator is a nitrile-rubber compound. The Series consists of six isolators whose maximum recommended load ranges from 510 kgf to 1,632 kgf (1,124 lbf to 3,598 lbf) and their durometers are 45 and 60 ±5.
Advanced Antivibration Components
2101 Jericho Turnpike, Box 5416
New Hyde Park, NY 11042
(516) 328-3662,
http://vibrationmounts.com/NewProducts/RectangularMounts.htm
