LED lighting for freezers, fridges
Low-maintenance LF1E Lumifa LED light strips are for use in freezer or refrigerated display cases with temperatures as low as –40°C. They can also be used in testing chambers where temperatures are below freezing.
The strips providing uniform lighting while producing low levels of heat, thereby saving energy. The lights operate on 24-Vdc voltage and retain 70% of their initial luminance at 40,000 hr.
The Series is available in cool white (temperature: 5,000 K) or warm white (3,000 K), four lengths with a maximum length of 1,450 mm (4.75 ft), and three types: no lens, condensing lens, and dual lens.
IDEC Corp.
1175 Elko Dr.
Sunnyvale, CA 94089
(800) 262-4332
www.IDEC.com/usa/LUMIFA
