LED lighting rated for high-pressure, high-temperature wash downs
LF1D LED lighting units with an IP69K rating can be used in environments requiring protection from dust, as well as the ability to withstand high-pressure and high-temperature spray-downs.
The light strips are the brightest in their class at 67.2 lumens/W (wide) and 66.6 lumens/W (slim). The lights retain 70% of their initial luminance at 50,000 hr. The units, with die-cast aluminum housings and stainless-steel front covers, come in cool white (5,700°K), slim (10 × 1 LED array), or wide type (7 × 2 LED array) with 24-Vdc voltage.
IDEC Corp.
1175 Elko Dr.
Sunnyvale, CA 94089
(800) 262-4332
