Side-mount level switches
The LS-7 Series of side-mount pointlevel switches, available in several versions, are made from Versaplast engineered plastic for high temperature applications up to 300°F
Dec. 8, 2011
The LS-7 Series of side-mount pointlevel switches, available in several versions, are made from Versaplast engineered plastic for high temperature applications up to 300°F.
The versatile plastic is compatible with a wide range of challenging fluids such as oils and solvents and are suitable for use within methylene chloride and antifreeze tanks, and for low-coolant, low-hydraulic monitoring within off-highway vehicle and transportation applications. Specifications include pressure capability to 100 psi and a float arc of just 1.25 in.
Gems Sensors & Controls
One Cowles Rd.
Plainvlle, CT 06062
(800) 378-1600
www. gemssensors.com
© 2011 Penton Media, Inc.
