Rectangular connector housings
Epic Ultra connector housings withstand corrosive, electrically noisy, and mechanically challenging environments. The housing features nickel-plated zinc hoods and bases with stainless- steel hardware, and a brush-style cable gland, which provides a fast and easy way to terminate a cable shield with a 360°, lowresistance contact area. The housing and gland form a conductive shell — or Faraday cage — around the electrical contacts to virtually eliminate electrical interference.
The connector housing’s design improves both sealing and strain relief. The lip seal between the top and bottom housing components is recessed, so it’s enclosed by the housing when mated and latched.
Lapp USA
29 Hanover Rd.
Florham Park, NJ 07932
(800) 774- 3539
www.lappusa.com/EPICULTRA/
