ISO tie-rod cylinders
MH Series metric hydraulic tie-rod cylinders meet ISO 6020/2 160-bar standards. The products have pistons with cast-iron rings and polyurethane U-cup seals; rod and rod bearings with hard-chromeplated/ high-strength steel and bronze construction; and carbon steel tie-rods with rolled threads. Ten different bore diameters range from 25 to 200 mm, with working pressures to 210 bar. Multiple mounting configurations, as well as double-rod versions, are available.
Milwaukee Cylinder
5877 S. Pennsylvania Ave.
Cudahy, WI 53110
(414) 769-9700
