Stainless-steel enclosures
Stainless-steel enclosures have a continuous one-piece silicone gasket that provides an IP66 rating for dusttight and watertight operation. The VC4X and VH4X enclosures come in 304 or 316L stainless steel and include standard lift-off hinges for easy removal of the cover. The standard ½-turn door latches include a double bit insert. Mounting feet can be horizontal or vertical and an internal/external earth stud is included.
The enclosures can be drilled to match customer specifications and equipped with mounting DINrail and terminal-block assemblies.
Adalet
4801 W. 150th St.
Cleveland, OH 44135
(216) 267-9000
Related
Sponsored
