Bearings and accessories
Precision-machined bearings
Precision-machined bearings and assemblies are available with ¼ to 6 in. ODs.
Features & benefits
Available in a variety of materials, including carbon steel, stainless steel, and engineered polymers
Applications include automotive and off-highway vehicles, machine tools, conveyors, material handling, packaging and food processing machinery, printing, and textile
Kilian Manufacturing
Altra Industrial Motion
(815) 389-6336
www.altramotion.com
Circle 151
Steel-housed bearings
Dodge Steel-Housed Imperial HD mounted roller bearings combine Imperial bearing technology with a cast steel housing and are designed for heavy-duty applications.
Features & benefits
Steel housings available in pillow block, flange, edger flange, and piloted flange configurations
Adapter mount system makes bearings easy to mount and dismount
Nitrile multiple-lip seal resists heat and chemical breakdown
Sealing system protects high capacity, double-row spherical bearing elements; seal also provides a flinger
Baldor Electric Co.
(479) 646-4711
www.baldor.com
Circle 152
Needle bearing cam followers
BBXCAM-CN Series needle bearing sealed cam followers feature hardened and ground outer races and low-carbon alloy steel hardened studs and inner races for reduced friction, quiet operation, and increased durability.
Features & benefits
Hex-head and slotted-head styles available
Nominal IDs from 1/2 to 4 in.
May be lubricated through the head end only; clamping torque based on dry threads
Quality Bearings & Components
(888) 276-4787
www.qbcbearings.com
Circle 153
Bushing bearings guide
A new selection guide includes product overviews and comparisons, specifications, and ordering information, as well as an engineering appendix to help users specify, install, and maintain ball-bushing bearings.
Features & benefits
Metric Super Ball Bushing precision bearings offer a coefficient of friction as low as 0.001, allowing smaller and less expensive motors, belts, gears, and ballscrews when replacing high-friction plain bearings
Stainless Steel MultiTrac Ball Bushing bearings suitable for harsh environments with temperatures to 180° F; multi-track design delivers up to twice the load-carrying capacity of conventional linear bearings
Stainless Steel “A” Ball Bushing bearings resist rust and corrosion; maximum system rigidity in challenging application environments including vacuum, ozone, and mild radiation, in temperatures to 600° F
Thomson
Danaher Motion Co.
(540) 633-3549
www.danahermotion.com
Circle 154
