Thermowell/removable sensor
June 1, 2011
The PRS-TW-M12 Series sanitary thermowell/removable sensor can be used in clean-in-place systems where it can be removed for calibration or service without disturbing the system.
Features & benefits
  • Four-wire, Class-A, PT100 RTD with an M12 connector plug; 3-A-approved thermowell; wetted surfaces of 316L stainless steel, surface finish of 32 µin. or better
  • Operates in -50° to 200° C; compatible with two, three, or four-wire RTD instruments
Omega Engineering Inc.
(203) 359-1660
omega.com/temperature/pdf/PRS-3-100-TW-M12.pdf
Clean. Compact. Less heat.
April 16, 2025
