What does it take to establish a single, authoritative product record as the default source of product truth across the enterprise?
The single source of truth is what we're looking for, and it's good for many things, especially quality.
The digital thread starts with requirements and coming to quality. Those requirements should set out measurable expectations for the product. How long should it last? What is the intended use of the product? How many hours will it run? What kind of loads will it be exposed to?
And that needs to be broken down into the parts and pieces of the product, to the software, to the hardware, to the electronics, to really understand what it is that each of those parts needs to contribute to that.
When we have those requirements, when we have them broken down to the part, we then need to check whether really those benchmarks and thresholds are being reached and whether the product as a total then behaves as it was defined in the previous stage.
How can field failure reports feed back into design decisions without forcing engineers to replace the systems they already use?
First of all, you need the connection — that's what we call the digital thread. We need traceability from requirements to design to manufacturing to service, and to the actual service incident or service order that the customer had to replace a faulty part. A lot of companies have those data sources in some shape or form, but they're not connected well enough.
In the age of AI, we have an opportunity if we have that digital thread. We bring it together — something we would state at PTC as the intelligent product life cycle — so you can learn from all of those data sources, whether they are from our products or external products. You have them connected and get that feedback together so the designer for the next iteration, or for the correction of maybe that quality cost-heavy part, really understands what's happening there.
When software can propose the design, where does the engineer's judgment stay in the loop? And what will engineers in the near future actually spend their time on?
I would hope they spend much more time on designing the actual products.
We see there is a lot of engineers' time lost in the process. I hear from customers that about 5% to 7% of an engineer's time is spent transcribing data from one system into another.
When designers work on their actual product design, they still, in many cases, need to create drawings that cost them another 20% to 25% of their time, simply transferring the information from 3D to 2D.
It would be even better if we had full transparency and full fidelity of information throughout the process. And we would have means to filter that down to the needs of the respective role that is working with that information, instead of transferring it into different file formats and different representations.
To learn more about PTC, please click here.
Watch the Video QuickChat.
Listen to the Podcast.
Sponsored by:
