Elastomeric elements
A line of Swiss elastomeric elements for improved tensioning, suspending, oscillating, and vibrating devices is available. These elements are recommended for a range of manufacturing industries that require or make self-opening and closing hinges, oscillating bearings, chain and belt tensioners or shock-absorbing mountings. These elements can replace spring and bearing combinations, and with no metal-to-metal contact, they eliminate the need for lubrication and diminish audible noise.
Lovejoy Inc., 2655 Wisconsin Ave., Downers Grove, IL 60515, (630) 852-0500. Hall 26; Stand E34
