Push-to-close latch
Designed and built by Southco, Concordville, Pa. (southco.com), the latches install easily with only five screws and can be used on right-angled cabinets. The keeper or striker is adjustable to compensate for variations in the door, panel, or frame. The latches are constructed of high-density plastic and stainless steel, giving it less weight and corrosion resistance, and are available in four finishes.
Related
Sponsored
