Miniture Force Sensors
Miniature S-beam-type force sensors are designed for tension and compression testing for limited-space applications.
The Series SJR sensors are 0.7 x 0.3 x 0.75 in. and have threaded holes for mounting attachments or implements. The sensors feature built-in mechanical overload protection up to 1,000% of full capacity and are accurate to within ±0.2% of full scale. Capacities from 0.25 to 100 lb are available.
Mark-10 Corp.,
11 Dixon Ave., Copiague, NY 11726,
(888) 627-5836, mark-10.com
