Housing For Sensors
IP67 housing protects C-Series modular linear-position sensors in applications subjected to dust, moisture, and other conditions that can interfere with operation.
The housing lets sensors be safely and securely installed externally. The device is well suited for small to midvolume uses where embedded design may not be possible. C-Series sensors are for OEM products such as medical devices and small cutting tools.
MTS Systems Corp., 3001 Sheldon Dr., Cary, NC 27513, (919) 677-0100, www.mts.com
