Miniature On/Off Slide Valves
The M3SV-N-M3M3 slide valve provides efficient on/off control of fluids. When the sleeve is moved to the "ON" position, fluid passes through the valve. Attachment can be direct to the device using its M3 metric threaded port or via barbed or compression fittings to plastic or metal tubing. Panel mounting is not required. The slightly larger MSV Series offers 10-32 UNF threaded ports in either two-way or three-way configurations.
Beswick Engineering Co. Inc., 284 Ocean Rd., Greenland, NH 03840, (603) 433-1188, beswick.com
