Positive-Displacement Pump
The 1000 positive-displacement pump is engineered for trouble-free handling of materials such as shear-sensitive chemicals, adhesives, lime, slurries, and viscous crude oil.
The pin-type universal joint is sealed and lubricated for minimal maintenance and long life. The pump's two-piece drive shaft allows easy assembly, maintenance, mechanical seal access, and eliminates complete pump disassembly to service the mechanical seal. Additional features include low shear pumping action; smooth, nonpulsating flow, 0.38 to 320-gpm flow rate; and 350-psi pressure capability.
Moyno Inc., Box 960, Springfield, OH 45501, (877) 486-6966, moyno.com
