Sealless Peristaltic Pumps
MityFlex Series-4500 high-flow pumps run on 115 Vac/60 Hz and use variablespeed controls for flow rates from 0.04 to 3,800 ml/min.
The 78.6-oz unit comes mounted on 12-gauge zinc-plated steel and measures 4.6 x 5.5 x 7.4 in. The OEM pumps are specified in designs for medical equipment and laboratory devices. All OEM models are self-priming and sealless, capable of handling a wide range of viscosities, from air or gases, to heavy slurries. In a peristaltic pump, the material to be moved only contacts the tubing, maintaining safe transfer of food products, ingredients, beverages, and pharmaceuticals.
Anko Products Inc.,
3007 29th Ave. E, Bradenton, FL 34208,
(800) 446-2656, www.ankoproducts.com
