Rugged Enclosure
The rack-mount 4U rugged enclosure supports a wide range of passive backplanes, including segmented backplanes, supporting multiple systems in a single enclosure.
The unit has five high-output fans that blow air from front to rear through the enclosure. Easily serviceable 31/2 and 51/4-in. modular drive bays provide significant storage capacity. Dual hot-swappable 350-W power supplies provide redundant power. Designed for use in harsh environments, the 4U enclosure features reinforced corners, power supply hold-downs, flush-mounted LEDs, and completely secured cables. The enclosure's modular components and removable backplane tray provide easy servicing.
One Stop Systems,
735 S. Vinewood St.,
Escondido, CA 92029,
(760) 745-9883,
onestopsystems.com
