High-viscosity compound
A high-viscosity, rigid compound, Tra-Bond 216R01 has a lap shear of 3,600 psi with a room-temperature cure and 4,500 psi with a 65°C heat cure.
A high-viscosity, rigid compound, Tra-Bond 216R01 has a lap shear of 3,600 psi with a room-temperature cure and 4,500 psi with a 65°C heat cure. The material cures fast, setting in 5 to 7 min, and is UL94 V-O compliant.
Tra-Con Inc., 45 Wiggins Ave., Bedford, MA 01730, tra-con.com
