The unit is for test and measurement, avionics, multipoint radios, telecom, among other applications. The VSCO uses a 5-V supply, features a 135-dBc/Hz phase noise at 10-kHz offset, and is housed in a 9 14-mm surface-mount package.
Crystek Crystals Corp., 12730 Commonwealth Dr., Ft. Myers, FL 33913, (800) 237-3061, crystek.com
