Jergens offers a line of washers that include flat washers (case-hardened, low-carbon, or 303 stainless-steel), heavy-duty flat washers made of high-grade carbon-steel, and USAE heavy-duty flat washers that combine a larger outside diameter with a tighter, more precise inside diameter.
Jergens offers a line of washers that include flat washers (case-hardened, low-carbon, or 303 stainless-steel), heavy-duty flat washers made of high-grade carbon-steel, and USAE heavy-duty flat washers that combine a larger outside diameter with a tighter, more precise inside diameter. The line also has C washers, equalizing, and swing washers, square washers, and spherical self-aligning washer assemblies. The washers are said to meet most companies' fastening needs and Jergens provides quick delivery with no quantity minimum.
